KM-2560 strange errors (2H0-25)
  • hermias
    i have a problem . when i look up my device via webbrowser shown wrong model number (2H0-25 Status: OK) and also i cant see my toner level too.What must i do fix this problem thanks for any help . Sorry for my bad english
    here some info
    About
    MODEL: 2H0-25
    VERSION:
    • 23010
    Somewhere along the way someone has done a U020 All Clear, wiping out the machines destination code. Go to simulation U265 and enter 02 for Kyocera Mita, or 66 for Copystar. There are other less common nameplates (Utax, for example), but I don't know any of those codes. =^..^=
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      Hopefully that will correct it, otherwise you will need to use prescribe commands
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
