km 5050 jamming
  • srv
    • Aug 2008
    • 82
    km 5050 jamming
    Hi there.I have a km 5050 jamming from tray2.The customer has been complaining about this fault for the past 2 weeks but every time I called I couldn,t get it to jam until I saw it happen today.I ran 250 copies this morning ok and 1 hour later it was jamming again.I called back and found it jamming coming out of tray 2 getting as far as the next set of feed rollers and no further.I tested the feed clutches in service mode and they are fine.How ever the feed switches for feed 2 and 3 didn,t appear to be working when tested in service mode.There are only 2 paper feed trays on the machine so I swapped the switches after removing the feed section and checking the wiring for breakages.After rebooting I tested the feed 2 switch again in service mode and it registered that it was working but when I flicked the switch a second time it didn,t.Machine still jamming .I am going to upgrade the firmware during the week.Has anyone seen this?
    • 23010
    Two things commonly.
    First, there is a modification to the switch mounts to extend the actuator a little further out into the paper path. If you order vertical path switches you'll get the new style.
    Second, In the lower left door there are two idler shafts with one spring each to provide spring tension on the idler rollers. I install two springs on each shaft, and clean the vertical path rollers.
    • srv
      • Aug 2008
      • 82
      Thanks for the reply blackcat.I will order the switches and some springs but shouldn,t the switches register when testing in service mode(or at least one of them)or is there a problem with faulty switches with this model?
      • shep
        • Sep 2010
        • 108
        i had a 3232e and a 5035 doing the same thing, it was the switches, order the new ones and it should be fine.
          • 23010
          The problem with the switches is not that they are not actuating with your finger, the problem is that they are not actuated by paper passing. =^..^=
          • srv
            • Aug 2008
            • 82
            Hi guys,I replaced the switches and the machine is working fine.Thanks for your help on this one.All the best.
              • 23010
              Congratulations! =^..^=
