Fs-1128 mfp copier Scanner?
  • galumina
    • Sep 2010
    • 32
    [Misc] Fs-1128 mfp copier Scanner?
    Hello,My fellow Kyocera technicians I have just installed a Fs-1128 mfp copier. I was able to install printer functions and everything works except the scanner. For some reason the scanner will not work, Can you help me. this sounds crazy but ever since Kyocera the only thing that I have a problem with is with the scanner installation. Any help would be appreciated. Thanks.
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    hi l think it's so easy if you red the instruction by her handbook or her sm .
    BEST TECHNICIAN . NICE PEOPLE .
    • galumina
      • Sep 2010
      • 32
      ZaZa,
      I have used the manual to install this and scansoft Driver but it still does not work.
      thanks for writting
      • kagemaru
        did u configure the Kyocera Twain Driver?
        go to Start>Programs>Kyocera>Twain Driver Settings.
        Add FS-1118MFP
        • shep
          • Sep 2010
          • 108
          are you trying to scan to email or folder?
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1890
            Sounds like you may be a little "green" at setting up scanning. We need a little more info before we can help you though.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
