km 5050
  • T911
    • Jun 2007
    • 628
    km 5050
    i need the user and password for the command center for this one. command center manual only has the password as admin00. but not working i also may need a user name for this one. thanks t
    • 23007
    Somebody has setup a username/password on Command Center. You'll have to ask that "somebody" what they selected. There is no specific default. =^..^=
    • T911
      • Jun 2007
      • 628
      Thats what i thought. Can I reset the scanner card and if I can u think it will reset command center. Thanks t
        • 23007
        You can try sending the following PRESCRIBE commands to the printer:
        !R! ACNT "REST";EXIT;
        If that doesn't work, try this:
        !R! EGRE; EXIT;
        This one resets the engine board and is supposed to reset all passwords.
        As a last resort, you can do a U020 Memory Clear. But be sure to print the maintenance report so you can renter the data that changed. =^..^=
        • Ferdy
          • Sep 2010
          • 22
          this helped me as well....thanks!
          • T911
            • Jun 2007
            • 628
            Blackcat. That's what I had to do and it reset. Memory clear. Thanks
