Kyocera 420i (Olivetti Branded 4200MF) Wont Update Firmware
  • The-Peanut
    • Aug 2006
    • 192
    I have a Olivetti 4200 MF (Kyocera 420i) with a DF-780 finisher connected to it
    from install the machine shows a jam80 from sleep mode, there is a firmware uodate to resolve that issue, however for some reason when i go to update the firmware (by USB), i get no change on all sections
    i have followed the instruction by the letter with no joy,
    any1 had this issue b4
    ta
  • tech07
    • Aug 2008
    • 409
    I,ve been wrestling with a j80 from sleep mode for some time now..Updating the firmware will only fix j80 when copier is running and customer removes paper from bin before job finishes. The current version is 2.45a On the status page it will show a release date of 7/23/10..
    Have a tech support ticket going with Kyocera and will advise when solved..
      • 22999
      Use compact flash. It re-loads firmware even when it's the same version, unlike USB which skips same levels of firmware. =^..^=
      • The-Peanut
        • Aug 2006
        • 192
        hmm yeh, i went for the flash card, but the machine does not seem to have the slot, unless its behind the rear cover.
        i have a main board on route to try, but the mention with the on going Jam 80 issue after the update is a worry
          • 22999
          Both my machines have CF slots. Perhaps early production?
          According to the service manual there is a CFPWB attached to the IFPWB. I'm assuming that would be either near the network connector or tucked inside the back. =^..^=
          • The-Peanut
            • Aug 2006
            • 192
            yeh there is nothing external beside the network port, but i threw on a couple of new pcb boards that have the latest firmware on, and i'm still getting jam 80 codes, however not coming out from sleep mode now, just random
            not sure here but i'm still convinced the copier is not talking to the finisher in the same language, i'm trying another finisher next week
            • tech07
              • Aug 2008
              • 409
              Visited my Jam 80 from sleep mode copier today and reflashed firmware using compact flash ( slot is just above ethernet jack). This had no effect. I also noticed if the copier is turned completely off, Jam 80 occurs on first copy. The screen says copying for a few seconds but eventually goes into J80
              • The-Peanut
                • Aug 2006
                • 192
                tech07 that is bad news, sounds like a change in finisher type will only solve the problem, i myself have been asked to try a new finisher, which is due in this week, but i can guess it wont work, we may have to upgrade the finisher.
                • richo
                  Got the same fault gents, currently got the finisher main board on order- let you know how it goes
