abnormal behavior of bypass
  • dipakpatel
    • Sep 2010
    • 34
    [Electrical] abnormal behavior of bypass
    i gave a 2-side mode from bypass and i wanted 3 sets of originals.
    The problem occurs in all type of paper size i.e A5,A4,A3,folio e.t.c
    result:-
    --1st set of copy was ok.
    --2nd set was not ok i.e paper was printed on both with same content .To elaborate one side content was printed on both side of paper.
    --Paper jamming occured in 3rd set.
    Note:
    --This happens only for more than 2 sets i.e. when we want only 2 sets of original then it works fine..
    --Also for more than 2 sets there is no problem when done using any casette tray but problem occurs only from bypass
    Any help is greatly appreciated....
    • 23010
    Interesting! What model? What version of the firmware?
    • luis8832
      • Dec 2008
      • 250
      I agree with black cat, what is the model of the unit and have u flashed up the firmware on this particular unit. Sounds like a firmware issue.
      • dipakpatel
        • Sep 2010
        • 34
        problem solved
        O.k. guys..the problem got solved..a single track from motherboard was left loosely connected...The machine is working fine and its KM 4035..
        thanks for showing interest..
        • luis8832
          • Dec 2008
          • 250
          Happy you resolved the issue there buddy.
