Kyocera 2560
  • Frank L
    • 30
    Kyocera 2560
    Can the 2560 do postscript and if so how ? Thanks Frank
    • 23009
    You bet. Go to the driver, right-click to Properties, Device Settings, PDL, select the print emulation you like: KPDL (Kyoceras version of PostScript), PCL XL, PCL-5e. Just be sure that the machine is set to "automatic" emulation, or match your emulation settings (settable from the copiers web interface).
    To check machine settings just print a Status Page.
    If you've got a lot of users, I prefer automatic. =^..^=
    • Frank L
      • 30
      Thank You
