more on u131
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    more on u131
    been doing more digging, since I'm no factory tech, and factory tech in my region pretty much dont care.
    I understand the concept, basically its a control system with a process and setpoint.
    say the machine sets value at 138, then it make sure the process(toner output value)is close to 138 while compensating all other elements.
    What I dont understand is there are machine that I'm seeing that has (180,179) value.
    I'm taking a wild guess that the toner coverage is proportional to u131 value. If it is so, can one intentionally undertone to save toner?
    Idling colour developers are not healthy developers.
    • 23007
    Yes. It's called "EcoPrint". If you want light copies, this is the way to go. I wouldn't go screwing with developer density unless you want to buy more developing units in the near future. =^..^=
    • jmaister
      certified scrub
      • Aug 2010
      • 755
      there's one machine that's undertoning by 30 points on K and C, any remedy before replacing DLPs?
      ratio: K 6%, C 6 %, M 11%, Y 11%.
      symptom: intermittent background, meter: less than 50k
        • 23007
        You can try a Developer Refresh in the System Menu > Adjustment/Maintenance.
        If you are seeing background, I suspect this won't help though.
        Is this a TASKalfa CS-250ci/300ci/400ci/500ci? Firmware version 11.00 is supposed to address this issue (with the developer unit changed at the same time). =^..^=
        • jmaister
          certified scrub
          • Aug 2010
          • 755
          It is taskalfa, it has v11 firmware, mutilple calls on same issue.
          Me thinks grounding issue, they had multiple cf codes the first 10k
            • 23007
            You might do a HDD re-format, then re-load v. 11.00. That has been known to solve some of those cfxxx code problems. First do a U917 backup, and be prepared to re-enter your scan to email/SMB/FTP information.
            • kyocera.team
              • Aug 2010
              • 126
              one more thing, u100 AC Auto Adjustment put it off
