Unexplained lines on scans
  • BHRLC
    • Nov 2013
    • 77
    #31
    Re: Unexplained lines on scans
    Well it seems 3LJ02280 didn't come in for some reason, boss says it was just duplicate?
    I misread the service bulletin - they didn't revise the slit glass, the service part is just a "sheet" of
    thin plastic that you place ON the left side of the slit glass. Interesting. Hope it works.
    • BHRLC
      • Nov 2013
      • 77
      #32
      So nothing worked...
      I installed the Bulletin "fix" sheet piece - same issue of multiple vertical streaks
      The only thing that even came close to remedying was setting U068 to -3, the streaks
      are just less on that setting. Tried the "line correction" setting as well - no change.
      It seems "Color Selection" setting in Function menu is missing?
      I tried changing "Auto Color" correction to 1, no change as well.
      • BHRLC
        • Nov 2013
        • 77
        #33
        Fixed - Coworker spotted some fine goop on the slit glass.
        Kicking myself in the rear now.
          • 37495
          #34
          Always, Always, Always the first thing to check for lines is the slit glass. I like to use alcohol wipes as they will remove small ink spots that are hard to see.
          • Zackuth
            • Aug 2009
            • 448
            #35
            I always tell my customers to rub the slit glass with their thumb a few times, then use alcohol. Sometimes the goo gets a bit stubborn about removal.
            If at first you don't succeed, redefine success
            • BHRLC
              • Nov 2013
              • 77
              #36
              Didn't think about getting alcohol wipes - will stock up now. AND rub the glass with my finger.
              I cleaned the slit glass with "super blue" before, I'm still asking myself how it didn't remove it when
              coworker used just a dry paper towel.
              Thank you, guys
