export address book to xml file or csv from 520i
    • 30284
    can you export address book to a xml file or csv file ?
    • 23009
    For certain, you can export and import addressbook entries using simulation U917. This file is in CSV format but is encrypted. If you'd like to edit the files contents you can use KM Setup Tool version 1.3.1211
    I do not know of a way to export that data in an un-encrypted form. =^..^=
