when i print A-3 PAPER taskalfa 520i 2 inch front cover side print vary light rest is ok i change drum and developer unit also but problem is same what i do
taskalfa 520i
Tags: 520i, bypass tray, change, change drum, developer, developer unit, drum, front, front cover, light, paper, print, side, unit, vary
The first thing to determine, is: Is it scanning or is it printing?
Does the problem appear on U089 test prints, or Status Page, or Counter Sheet?
If yes, it's print engine. I'd look more closely at the developing roller.
If no, It make sure that the scanner mirrors and lenses are clean.
=^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Paul@justmanuals.comComment
