KM4050 False add paper from PF750
  • davydoodledo
    • 21
    I have a KM4050 that gives a false add paper from the one tray PF750 LCT. Trays raise ok, and sensors ok, plastic tabs not broken off feed assy.
    FW ver 2000.027.018
    Any ideas?
    Thanks............
  • Jimbo1
    • Mar 2008
    • 845
    We wound up putting the cork pad used for the seperation pad on the ADF for the 2560 series in the tray so it actually raised the arm a little higher when the tray got to the top.
    Part no: 2A107060
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
