Driver Kx Problem Ta250 Ci
  • spiderman76
    • Mar 2009
    • 59
    Goooood-morning !!!!!!
    I have this problem: whether to print the attached file number 1 in A3 booklet mode, the machine locks out and print as you can see in the attached number2. Can you help me??
    the booklet in A4 format is printed correctly
    • 22999
    http://www.copytechnet.com/forums/ky...r-cs400ci.html
    Could this have something to do with it? =^..^=
    • spiderman76
      • Mar 2009
      • 59
      Uhm .... Why the booklet A4 is printed correctly while the booklet A3 isn't printed correctly ???
      With other printers (for example , Oki... ), the print is perfect!!
        • 22999
        You don't really need me restate the same response 4 times, like the referenced thread, do you? I have nothing additional to add.
        Why is the sky blue?
        Why do bears crap in the woods?
        Why ask why?
        (Does this make me an existentialist?) =^..^=
