PF-75 ISSUE
  • LNorris
    • Sep 2008
    • 645
    PF-75 ISSUE
    i have a KM4035 with a PF75 under it. the right side cassette will not acknowledge paper is there. i can run the left side dry and it will not pick up the right side. if i put paper just in the right side, it states "add paper". i have replaced the paper empty sensor, checked all wiring back to the board and reset the board.
    i have moved sensors (led type) around and no change. i have checked voltage (or tried to), as pin 13 and 14 are pulse (apparently either i dont know what i'm doing or the meter wont pick it up).
    any ideas/suggestions?
    • 22932
    How about a U906 partial reset? =^..^=
    • LNorris
      • Sep 2008
      • 645
      Yeah, about a 100 times..lol
      • Jimbo1
        • Mar 2008
        • 845
        The frame is not broken is it?
        "Some days you get the bear, some days the bear gets you."
        Cdr. William Riker
        • Jimbo1
          • Mar 2008
          • 845
          Sounds to me like a job for "The General"!
          You know who I mean. The guy with more antennas on his car than a radio station?
          Cdr. William Riker
          • LNorris
            • Sep 2008
            • 645
            yeah, but since i dont know from one day to the next who the tech rep is anymore...i have the General working on my 550. thats a little more priority for us.
              • 22932
              You might check the spring loaded couplers that drive the lift. I vaguely remember something about twisting lift motor shafts, and couplers that don't return. =^..^=
