Color problem Taskalfa 250ci
  • micsilva
    • Aug 2025
    Hello,
    I have a color problem when I print A4 with some foto
    in F/R. In a band on the left side of the paper the tint is different.
    I put some red line were is the problem.
    This from Acrobat X Pro and other program (Word).
    What could be?
    • 23010
    Take a look at the U089. gray test patterns in all four base colors. Which color (CMYK) shows the problem?
    I would start with cleaning the optics and doing a color calibration. =^..^=
    • micsilva
      Thanks for your answer
      I don't see problem in gray patterns in all four colors (just some small dots). Calibration ok.
      Sometimes in the left side of the white paper there is a slight magenta haze, high as the photo,
      as if it were a continuation of the photo.
      • kyocera.team
        • Aug 2010
        • 126
        first im with Mr. black cat use program u089 then clean the opyical section if then try color registration then color calibration and test it how it will be ....
          • 23010
          If you've got the original electronic document, I'd download Colorpic. With Colorpic you can get numerical RGB or CMYK readings from specific areas of the original, to determine of the color difference is happening in the electronic original. If yes, it's out of your hands. =^..^=
          • micsilva
            Have you seen the orginal document? have you noticed that the colors' difference is quite evident, there are two parts. I've been printing for the last three weeks about 1000 similar pages (I mean pages with two photos) with different photos, and the problem comes often. I cleaned optics, I did calibration, color registration. No change. In the file I attached now, is very difficult but you see a magenta haze between the two red line. The same thing in the picture above. Even this is often. Thank you for you attention, you are very helpful.
            • kyocera.team
              • Aug 2010
              • 126
              did you clean the main charge ? clean it or replace it ...
