sloppy K clutch on Voyager
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    Its kinda figured out, but just asking for opinions.
    K clutch for 4035e is not turning at full speed, its actually stuttering a abit.
    clutch or board?
    Idling colour developers are not healthy developers.
    • 23010
    Yeah. I've seen this around 1M prints. The bronze bushing on the inner side of the main drive back will oval out, and the gear inside will start to wobble and skip. If you've made it to 1M, I'd replace the main drive and PF drive assemblies, plus the waste toner drive clutch. When you examine the parts you'll find some extreme wear.
    As a temporary measure, you can replace or rotate the inner bushing 180 degrees, so you're wearing on a different side of the bushing.
    I've changed a lot of these developer drive clutches, and I was quite surprised when the shaft & gear fell right out of the clutch pack upon disassembly. That had never happened before. =^..^=
    • jmaister
      certified scrub
      • Aug 2010
      • 755
      missed out the important part, c7101.
      and no, not even 500k.
      will take note on the 1mil bushing.
        • 23010
        You can change the bushing without the total gear pack removal and disassembly. The shaft looked bad too, tapered to a point.
        If you do disassemble the gear pack, replace the two stage gear Z54L/Z26L (302FZ31401) that drives the color developing units. The couple dollars for the gear is insignificant compared to the 3 to 4 hours labor time, and it will strip eventually.
        • jmaister
          certified scrub
          • Aug 2010
          • 755
          oh crap, there's one more thing I forgot, it was printing 256 gradation in blank. I was able to get couple going before 7101 shows up.
          sry for the confusion, this is the full problem
          7101, clutch still turns but sl..ipp..s (observed this by watching the coupler while the KDLP was out, u30 motor test), prints blank when its able. swapped KDLP, no help
          u131 on auto, (140, 140) on k
          u131 on manual no adjustment(looking from auto), (140, 0) on k
          edited
            • 23010
            Yup.
            That's the symptoms I've seen.
            I've seen a couple black developing drive clutches begin to slip, causing the same symptoms (less the stuttering). =^..^=
