KM 4030 shows error code C0910
  • dipakpatel
    • Sep 2010
    • 34
    [Error Code] KM 4030 shows error code C0910
    i am not able to use fax in KM 4030 .machine shows error code C0910.
    manual shows Fax software upgradation but i have no idea about this.
    please help me.
    thank you.
    • 23009
    The chance of firmware fixing this is slim, in my opinion.
    Fax firmware is loaded via compact flash card. There's a CF port under the upper right hand cover for machine firmware and fax firmware. If you've got a print system installed there will be a second CF port for print card firmware only.
    You download the firmware from KMAConnect
    It is not necessary to format the CF card beforehand. Unpack the firmware and copy the files to the root drive of the CF card.
    Turn main power switch (on the right hand side of the machine) Off and unplug the power cord.
    Insert the CF card into the CF port under the upper right hand cover.
    While pressing & holding the Copier button, Plug in power cord. Power On. Continue holding Copier button until "Please Wait" is displayed.
    Enter Service Mode > U926 > Execute > Start.
    When the firmware is finished it will display Program: Execute 0100, Checksum xxxx, Code yyyy. Font: Execute 0100, Checksum xxxx, Code yyyy.
    Code 0000 = success, Code 0203 = no data present on CF card. Exit service mode.
    Remove the CF card.
    Enter Service Mode > U019 to check that the fax firmware has been updated. Exit Service Mode.
    • kyocera.team
      • Aug 2010
      • 126
      dear dipKtel
      Mr.blackcat explain exactly what you want to do, no one can tell you better than this answer
      Thank you blackcat
      • dipakpatel
        • Sep 2010
        • 34
        thank you....
