TASKalfa 620 Code C-0630
  • duane@pbbsinc.com
    • Mar 2011
    • 77
    I have this repetative code that keeps popping up on my TASKalfa 620 does not seem to matter if you copy print or scan it seems to happen. C-0630 code keeps popping up. I have tried a main pwb board and it did not fix the problem. machine has been updated with latest firmware according to my NEC support please help if you have any ideas...
    • 23009
    Take a look at the developing bias terminal. It will also cause light copies. For pix look here:
    http://www.copytechnet.com/forums/ky...ank-image.html
    • jmaister
      certified scrub
      • Aug 2010
      • 755
      KM knowledge base mentioned KM3035 having this issue due bad contacts. TA colour can have this issue when the CIS cable is loose.
      cant find any thing with 620/6030
      Idling colour developers are not healthy developers.
        • 23009
        Maybe KMA hasn't heard of it yet.
        Take a look. Oh, and don't use any lubrication on that contact. Conductive grease will just cause more light copies and codes. =^..^=
        • D Colour
          • Oct 2008
          • 216
          I'm with jmaister on this one. We have had this code a few times on the TASKalfa 250ci and it was nothing but a loose ADF cable.
          C0630 DMA problem
          Everything that has a beginning, has an end.....
          • Mustii
            • Aug 2010
            • 4
            i had this same problem, it was a HDD-Problem!?!?
            1. Remove the Hardrive
            2. Format (NTFS) on a Windows System
            3. after Format clear the Partition
            4. install in the Machine
            5. switch on Machine, C0640 appears on the display
            6. enter Maintenance mode 10871087, U906 Resetting partial operational control
            7. open the front door, switch Machine off/on ,
            8. enter Maintenance mode 10871087, U024 HDD fomatting
            I hope I could help you
            With kind regards from Germany
            Oktay ;-)
            • duane@pbbsinc.com
              • Mar 2011
              • 77
              Thanks for all of your help but we finally found solution too the problem. There is a memory stick on the main pwb board and Nec. or Kyrocera does not carry this part right now . When i installed the main pwb it did not come with this standard memory not an upgrade. This memory was bad and did not work on copy scan or print on big spool jobs but with out it it would kick a 0610 code so i thought it was good...If anyone has this c0630 code try memory sticks from a stripper older model it was the same memory and fixed my machine....
              Thanks too all who replied.
