KM FS-1128MFP scan to e-mail gmail
  • TTL
    • Dec 2008
    • 127
    Hi,
    I have a question about this machine, I want to scan to e-mail and receive reports from this model, if the configuration is with an internal e-mail, everything work's fine, but if I try with Gmail give me a error.
    The network settings are properly configured, the smtp I think they are too. When I make the test connection, everything is fine. But when send a e-mail don't work, give a error.
    Someone work with the gmail smtp in this machine? something needs to change?
  • colin
    IT
    • Sep 2010
    • 38
    You will not be able to use gmail as your smtp server. They no longer allow free usage of there smtp servers.
    • TTL
      • Dec 2008
      • 127
      oh, ok.. Thanks.
      • colin
        IT
        • Sep 2010
        • 38
        This has been an option for us...
        SMTP Server - smtp2go The Worldwide SMTP Server
        • Aries_1
          • 42
          Its not that gmail disallows free usage of their emails, its that Kyocera does not support the type of encryption gmail uses.
          • colin
            IT
            • Sep 2010
            • 38
            You can use an SSL encryption type with Gmail. Kyocera offers SSL connections. Gmail does not accept the header types that Kyocera uses, they are putting a stop to using there SMTP servers as an open email relay. I shouldnt have used the term free... there just flat out not allowing open relay mail through.
            • tmaged
              Owner/Service Manager
              • Oct 2008
              • 1889
              Google uses TSL which Kyocera doesn't support. I've been told by a customer that he used aspmx.l.google.com as the smtp server. This one allows an unencrypted connection. I haven't verified it, but he said it worked.
              Hope that helps !
              -Tony
              www.dtios.com
              Become a fan on Facebook
