5035 fax question
  • CCS
    • 266
    5035 fax question
    I don't normally work on much Kyocera product, but got a 5035 into the shop which I was running up and checking out, when checking the fax outgoing seems fine, but incoming seems to be very slow in-between pages, like it pauses 15 or 20 seconds for each incoming page, is this a normal speed for incoming fax on the 5035?
    I was looking around in the settings, changed reception bulk output to "on", seems like it got somewhat faster, but still too slow I think...
  • Hemlock
    • 432
    Try multiple sources, and ask them to set resolution as low as possible, to see if it's on the sending end. If all those take excessive time, you may wanna check for noise on the line that could be interfering with transmission.
    “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'” (Isaac Asimov)
      • 23009
      Just take a look at the reception times on the activity report.
      Think of it this way: You have a 35 ppm MFP receiving page data at 5 or less ppm. So it takes the machine 1.71 seconds to print a page, but 12 seconds or more to receive each page. That sounds about right. To complete the math, What is the average reception time? =^..^=
