Kyocera Falcon I scanning wonky
  • Jimbo1
    • Mar 2008
    • 845
    I have a KM-3530 that is cutting off about 1/2 inch on the left side when you scan to pc off the glass.
    Thoughts?
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
  • Metalvoc
    • Sep 2008
    • 155
    Adjust your margins first using U402, U403 & U404, in that order. When those are accurate, make sure that you have "Full Scan" enabled in the scanner default settings. By default full scan is turned off.
    I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
    • Jimbo1
      • Mar 2008
      • 845
      K....sounds like a deal. Thanks.
      Cdr. William Riker
