KM-2050 drum reset for use w/generic
  • Toner Boy
    • Aug 2007
    • 357
    Is there any way to reset the count through service mode w/out using new drum unit for the reset? We installed a generic drum/blade and cannot reset manually. Many thanks for advice given.
  • correo.tony
    • 72
    Put 10871087 and run sim 251 to clear drum and maintenance service counters.
    Bye !
    • Toner Boy
      • Aug 2007
      • 357
      Many thanks!
      • taskalfaman
        • Nov 2009
        • 137
        drum reset is sim 110
        • Toner Boy
          • Aug 2007
          • 357
          Yes but 110 won't clear it like the fuser clear or the maintenance clear, I believe the drum contains a fuse that must blow on installation? Or is there another trick to get 110 to work? I cleared 251 but don't think it cleared the drum, not sure and the location is 1.5 hours away. I'm assuming some voltage correction is applied when the drum count gets cleared.
          • taskalfaman
            • Nov 2009
            • 137
            login in with 30363036
            then it is possible I think!
            have fun
            • T911
              • Jun 2007
              • 628
              110 for drum and 251 for pm. only if pm light is on though based on firmware. good luck t
              • jummamaster
                • Mar 2009
                • 99
                have fun
                what mode is this?
                Ricoh Error Codes
                Canon Error 5100
                Canon Error B200
                j
                c
