Is this device compatible with prescribe???
FS-1016 and prescribe???
All the Kyocera-made machines are compatible with some PreScribe commands, but the real question is which commands? Not all PreScribe commands work on a specific model. And there is no list that I know of, saying which commands work on which models.
What are you trying to do? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
I'm trying to teach myself prescribe... But I can't get the fs-1016 to do ANYTHING at ALL! I've played with a fs-c5100 a bit on the network too and it looks like I can do a few things there!
Ultimatly I want to load a letterhead onto the fs-c5100.
at the moment we print out a bunch of letterheads then load them back into the mp tray and print on them again!
ive been playing around with the following tools:
iclink, print driver utility, and a prescribe macro generator.
i think there might also be settings in the command centre that i need to do???
i find all this prescribe stuff very confusing but very very interesting and i would love to learn more!
i also have an installation next week 2 taskalfa's 250ci's and 5 fs-3140's this customer has 3 diferent letterheads that they use... that setup is going to be a tricky one!Comment
Start with a few status pages:
Wisecore machines typically use:
!R! CALL BSTP;EXIT;
Previous technology uses:
!R! STAT 1;EXIT;
Or how about an event log:
!R! KCFG"ELOG";EXIT;
There is nothing that needs to be enabled for PreScribe scripts to work. If it takes firmware PreScribe must be available and functioning. Firmware is all PreScribe commands.If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
ok this morning i'm playing with the fs-c5100 I've installed a second print driver using logical print driver port 9101.
i'm looking for commands for the start of job string and end of job string.
-for making a carbon copy. something like !R! CCPY E and !R! CCPY D;EXIT
Thanks guys!!! I'm learning a lot!!!Comment
