Problem With Toll Free Fax Number On KM-3050
  • jockey
    • Aug 2008
    • 52
    I have a issue with a KM-3050 when faxing to Toll Free numbers, Im sure it has to be a setting but 1-800 & 1-877 numbers will not go through, all other numbers will go through fine, has anyone else seen this before?
    • 22999
    Have you tried dialing these numbers on a handset connected to the fax line? Often such phone numbers are block by the PBx. If that's the case, there is nothing that you can do on the machine to override PBx settings. It's up to the company that services the PBx. =^..^=
    • jockey
      • Aug 2008
      • 52
      When they connect there small desktop fax the toll free numbers go through with no problem, so don't think it's a switch or line issue
      • Jamiesdad2
        • May 2009
        • 29
        I have had 2 4050's do this. Enter sim 631 and set error correction mode (ecm) to 0 and it should work to all toll free numbers.
        • jockey
          • Aug 2008
          • 52
          I entered sim 631 it had, (ecm TX - on/off) (ecm RX - on/off) and (CED Freq 2100 & 1100) didn't see how to change (ecm) to 0 just said on/off
          • Jamiesdad2
            • May 2009
            • 29
            Turn ecm TX to off
