kyocera fs-1018mfp--- headache
  • belloumi29
    • Jul 2025
    hi every one
    it's my first participate
    i have kyocera fs -1018 for 6 year ,and in this period it's work very
    very well intil one week later..............
    the problem is i get dirty copy......so i change drum because this one printed over 70 000 copy......
    so i buy a new drum (80 euro)...and when t test it ..i see tath there is a shadow on the deep of page (page not exactly white) so i try to clean and no result
    help me please............................................ ..
  • LNorris
    • Sep 2008
    • 645
    what happens when you print? is the shadow just on copies?
    • JustManuals
      • Jan 2006
      • 9838
      Just Manuals | The Internet's largest selection of manuals | Instant Downloads
      Paul@justmanuals.com
      • belloumi29
        yes ---mr lnorris---- like a shadow on copy--when to copy a white paper the result is white copy but there is some shadow in all the page
        • LNorris
          • Sep 2008
          • 645
          if it is happening just on copies, i'd look at exposure, if it is in a dirty enviroment, check mirrors. make sure firmware is up to date as well.
          • tcs04
            FORMER Techie
            • 1183
            OK, Hands up, Mainly a Ricoh tech!!, But we have an issue on some of our machines, if you lean on the front left corner of the doc feeder (Doc Processor in Kyocera speak?) and feed throught the doc feeder (Proccessor) you can get a dark shadow on one edge If the scanner has deformed and the original is not pressed against the slit glass. Try "Reforming" the scanner by lifting the front left edge while copying and see if the shadow reduces.
            • DWise
              • 895
              if it has gray background with scans and prints, I'd check the developer unit
              Do for one what you wished you could do for everyone. - Andy Stanley
              • jewen25
                • Mar 2009
                • 197
                try to clean all Glass inside optical section if still there,you must dismantle the near the LSU you well see a small glass try to clean i think many dirt that cause white line that occur, like you said its a 6yr lod machine...
                ERROR HELP ME AND HELP YOU
                • jewen25
                  • Mar 2009
                  • 197
                  try to clean all Glass inside optical section if still there,you must dismantle the near the LSU you well see a small glass try to clean i think many dirt that cause white line that occur, like you said its a 6yr old machine...
                  • RABA
                    i think about toner quality...or bias regulator vr on drum unit vr
                    • dickierock
                      • 252
                      Hi,you must do a status page printout before you check any optics etc.If the status page has the shadow then its drum/developer problem.If no shadow then optics.
                      As you have already replaced the drum then I would suspect developer unit/toner problem.
                      • copy king
                        • 13
                        A lot of people these days are buying 'after market' toner and this doesn't always work overly well with the genuine toner when mixed. 1st port of call for me would be to clean out the devolper unit and restart with fresh toner, be it generic or genuine.
