km-c3232 black washed out
  • mrfuser
    • 1613
    Is there a way to increase just the black density on the KM-C3232? All other colors seems okay and the black DV was replaced not that long ago.
    Also, we notice that there appears to be light lines spaced about 1 inch apart as the copy exits. Is this failure of charge roller or more in the drum department?
    Kelly
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    about 1in? 1.5in (38mm) will be the charge roller. stop the job half way pass T-belt, see what the print looks like if its not the drum department.
    Idling colour developers are not healthy developers.
    • mrfuser
      • 1613
      washed out
      can you swap charge rollers with other colors to see if any change?
      Kelly
      • jmaister
        certified scrub
        • Aug 2010
        • 755
        How visible is it? u89 gray will give you clear view on which unit is causing the issue as it print from specified color only.
        I wouldnt swap the roller due to the machine has already lock onto(calculated/compensated) to its surface property, and because there's u89. (but for testing purpose, not stopping ya)
        u89> gray, hit start for K.
        u89 color> gray, hit interrupt, hit "full color", then "user choice"(i think), mono color, then C M Y.
        I think you need to print the color belt first to enable the mono color option.
        • mrfuser
          • 1613
          Problem with black for sure. u89 grey is very washed out. Guess I will have to bite the bullet and do a new drum/dv unit.
          Kelly
          • jmaister
            certified scrub
            • Aug 2010
            • 755
            before swapping the whole K set.
            can you hand crank the K dev?
