To reset this little spring on the DP of a TA420i.
page 14, item 48. DP750~~~ parts manual.
Original problem: jam in DP while duplexing, on second side only.
For whatever reason it came loose, there was no way to restring it back to the way it was as there was a extra loop of slack.(and I didnt know which way it was facing...)
Full disassemble, NO.
It was a pull-bend-cut job on the existing spring. The flap needed to be pulled to the centre, and the custom job did so.
If you have clients that duplex tons, know this spring! Its small, but it will(had) kick(kicked) you(my) arse.
Disclaimer: This is a temp fix, proper spring will be installed later on.
