5050 smb scaning 2203 code
  • shep
    • Sep 2010
    • 108
    connection timed out. it takes forever for it to do it. about 5 min per scan and then it codes, it happening on some computers and not on others, some windows 7 some xp. i have not seen this error and dont know what would cause it. i have disabled firewalls, i have used 445 port on the windows 7 machines and that has worked for some of them..... any other ideas???? thanks for the help.
    • 23009
    Are you sure it was SMB scanning? 2203 is specific to Email/FTP only:
    Send Email/FTP Error: Response Wait With Timeout. Response is not returned from the server, above specified time.
    Check the network connection (cable, network condition within LAN, etc.). =^..^=
    • shep
      • Sep 2010
      • 108
      yeah it is smb scanning, they are not set up for ftp or email scanning. my scan to email error code for smb scanning has it on there, it has the same explaination for all three smb, email, and ftp. i can pull the web browser from the machines, can not ping the machine though. it really makes not sense to me why its not working. ill try tech support today but past experience with scanning and tech support has not helped much. thanks
      • jmaister
        certified scrub
        • Aug 2010
        • 755
        You need a packet sniffer and a person that can diagnose with the tool, above paygrade not worth our time. Check dns setting before calling it a day.
        Idling colour developers are not healthy developers.
        • aragul
          • Dec 2007
          • 128
          That seems strange. Have you tried hooking up your laptop directly to the copier and pinging it and scanning SMB?
          • jmaister
            certified scrub
            • Aug 2010
            • 755
            A mixture of XP and 7 OS in the office means its not properly thought out when its upgrading. Therefore the network was the last thing on the "to do" list and likely they dont have the know how to set it up properly. If you have any decent IT in the office, 7 is just not the way to go, yet.
            Its either ICMP that has been turned off or you have multiple routers in the place. I've only been to one place that ping was purposely disabled. Other than for air tight security purpose "ping" wouldnt be disabled.
            Its more than likely that the packet was lost.
            edit: As aragul advised, plug the laptop in prove that it works on your lappy, have their IT person look after it.
            • shep
              • Sep 2010
              • 108
              Thanks for the replies its a head scratcher cause half of the people work fine so they know its not our machine, all the xp machines and about half of the 7 machines work, to make things worse they fired there old IT company and just got a new IT company that is working on it. so they don't know what all the old company did......
