Add paper in tray 1 on 2560
  • lees
    • Apr 2011
    • 95
    [Misc] Add paper in tray 1 on 2560
  • peterepeat
    • 84
    Had a very similar experience only when I reinstalled the fax card the message would come back. Thought it was a bad fax so I replaced it, - but nothing changed.
    Ended up reformatting the HD to resolve. Apparently a corrupt fax print job or something
      • 23009
      Hey, I've seen that before. I just felt a little tickle in the gray matter, all the way in the back corner ...
      "Load Paper Tray #1" when paper is full. When attempt is made to cancel the offending document from the Status screen "Cannot cancel fax or ifax receptions." is displayed. When Fax System (M) is removed message disappears, all but fax is restored. Corrupt fax reception is stuck in memory. Export user data to USB in sim U917. Note destination (66 for Copystar, 02 for Kyocera), SMTP, and IP address. Run Data Clear U022. The offending document will be printed. Re-enter destination & SMTP data and import U917 data.
      I tried a new fax board assembly on mine also, but it didn't help. =^..^=
