what are the differences btw km3232E and km3232
  • temas
    • May 2011
    • 22
    hello house,
    i am new to this forum.please what are the major differences between km3232E and km3232? are the developing unit interchangeable? and again can i use a new magenta dev unit in place of black dev unit?
    Do not find fault, find a Remedy, anybody can complain.
  • Scott
    • 196
    Yes but beware 1 of the major changes were the DV units... the non E had collar issues
    • temas
      • May 2011
      • 22
      please what do u maen by collar issues?
      • temas
        • May 2011
        • 22
        the issue is, am having a problem with km3232 black dev unit,then again i have a km3232E magenta dev unit i want to replace the black dev unit with.the magenta toner was flush off thekm3232E dev unit and the toner sensor was replaced with the onefrom the km3232 dev unit black sensor, but the machine prints first copy and comes up with code 7101.please help customer is on my neck
        • Scott
          • 196
          the collars on either end would crack and leave wierd toner lines down the pages and it was so bad that they updated them by sending eveyone new DV units. Then they came out with a new machine with the updated DV units as one of thier updates.
            • 23007
            The developing units are coded on the CRUM chip with serial number and color. The machine will know it's not supposed to have the magenta developing unit in the black slot or vice versa. You'll have to have a magenta developing unit for the magenta slot or it will code. =^..^=
            • Scott
              • 196
              My bad I did not see that you were replacing a blk with Mag or vise versa... cant do that but you can cross the E's with the NON E DV units same color
