C0630 on 250ci Taskalfa
  • aabarnes1
    • Mar 2009
    • 620
    This code relates to DMA/pwb- no tech bulletins or knowledge of this code. Any pointers please?
    Grant me the serenity to accept the things I cannot change.
  • daveyball
    • May 2009
    • 314
    I Had the same fault, i found the DMA board to be a bit loose, i replaced with our office machine, and it's been fine ever since, but so has the office machine, but i have since found out that cleaners where moving the machine around, and grapping it in the ADF connections area. Make sure the screws are all tight etc
      • 23009
      This error typically refers to CIS failure when scanning second side. I'm assuming that you've got the DP-760 installed.
      I would make sure that the DP connectors are well seated, then re-seat the CIS sensors. This may be one of the old style connectors without the protective cover. The last CIS I replaced caused a C3210 error. =^..^=
      • aabarnes1
        • Mar 2009
        • 620
        I reset using sim 906 and upgraded f/w to v11 and the code went awol so I'm not 100% on exactly what sorted it- but it's ok!
