11x17 folding... no booklet on a cs5050
  • shep
    • Sep 2010
    • 108
    we have a customer that runs a ledger document double sided and wants it to fold in half. no staples and its a single document only one page(two if you count the second side). for some reason we can not get it to do that, print or copy.. will the machine do it?
    • 23009
    Nope. The booklet function is designed for 1-up originals, whether electronic or paper originals. And it must staple the booklets. =^..^=
    • cbs
      • Apr 2011
      • 86
      I do not know if the CS5050 has the same functionality in booklet fold as the CS500ci series does; however, the CS500ci series will fold (without stapling) a duplexed 11x17 sheet. I haven't tested in on the new Taskalfa's yet.
      • jmaister
        certified scrub
        • Aug 2010
        • 755
        3000 sheet finisher will do that. I've seen it do it with KMC4035E.
        Is it from Microsoft Publisher? The original file has to be 8.5x11(portrait) single page, 1st with text/photo, 2nd to 4th blank. Under print menu, choose 1 page per sheet, and portrait. In KX driver, choose booklet or send to folding tray. Since its only 4 pages, staple function wont be activated.
        The new MS Office is really finicky in this regard.
        edit: are we talking folding with the 5050 or the available folding option with a big finisher?
        Idling colour developers are not healthy developers.
        • shep
          • Sep 2010
          • 108
          tech support says no it will not do it. because the original is 11x17 thanks for looking into it also.
          • jmaister
            certified scrub
            • Aug 2010
            • 755
            DOH! i've completely misread the original question, sry.
            edit: is the original based on a file? is tweaking possible and break it up to four 8.5x11 pages?
