Win7 OS will not print to 5035
  • Geo
    • 662
    Trying to set up printing for a 5035 on a pc running Win 7 with a 15' USB cable. Windows 7 is not finding the 5035,it only finds a unknown printsys(u). Pluged the USB into a XP pc and it reconized the copier and installed it.
    Does Win7 OS have problems installing Falcons with a USB cable or is it me?
    • 23009
    Windows7 definitely has problems with the USB ports. I don't know if there's a patch or OS upgrade, but it's the Windows7 for sure.
    I've been lucky. In the few situations I encouraged the user to use the network connection. =^..^=
    • jmaister
      certified scrub
      • Aug 2010
      • 755
      Win 7 definitely has problems.
      Idling colour developers are not healthy developers.
      • Geo
        • 662
        Ohh Joy !
        • Geo
          • 662
          Does anybody have a fix or workaround for this?
          • denden4h
            • Mar 2006
            • 31
            Are you using the Windows 7 driver or the KX? The Windows 7 drivers for KM seem to be problematic so I would recommend downloading the latest from KMA.
            • ignacio.cortez
              • Jul 2010
              • 176
              Re: Win7 OS will not print to 5035
              "This messages does not make any assumptions about you knowing anything about Windows"
              --- So I'm Making it as Basic as possible ---
              OK I had a similar issue, where it wouldn't find the USB Print port, so here is what I did:
              get the following text (between the dotted lines):
              Windows Registry Editor Version 5.00
              [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Print\Monitors\USB Monitor]
              "Driver"="usbmon.dll"
              Paste it into a notepad document, save it as [WHATEVER YOU WANT TO CALL IT].reg, make sure you have your extensions visible (chances are notepad will try to save it as [NAME].reg.txt (make sure you get rid of the .txt)
              Once you see a Registry Key icon (white page with a broken green rubik cube icon)
              double click on the link, it will add the Registry key to the system, Restart the computer (have the user log in) then try to add the printer again, you'll probably will get through and be able to install the driver using USB)
              If you cannot create the file, download this txt file, rename it [NAME].reg and then run it and restart.
              • kkendric
                • 301
                Definately download the newest drivers. If it found a print System "U" it found the print system for the 5035 copier, it just does not recognize it possibly due to wrong drivers on the system. Just a guess.
