kyocera km 2550 error c0960
  • javier4065
    • Feb 2007
    • 251
    display says error c0960 .What is the developer board? and what can I do to solve this code?.Thanks.
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
      • 22999
      It's the little crum chip in the developing unit identifies the unit's serial number, copy count, and compatibility with the engine.
      So the chip itself could be bad, the developing unit may be incompatible (did you just change it?), or there may be a wiring problem between the chip and the main PWB. =^..^=
      • javier4065
        • Feb 2007
        • 251
        thanks for your answer,but there are two chips, one of them is near to battery and a memory and another is on board in the middle of the machine with several conectors. what is the developed board.thanks.
          • 22999
          It's the only one on the developing unit. =^..^=
          • jummamaster
            • Mar 2009
            • 99
            After changing the board or developing unit, make sure that you insert the developing unit connector correctly on the engine PCB. There are two similar terminals on the engine pcb, if it is inserted in the wrong terminal, new developing unit board will also burn.
            Ricoh Error Codes
            Canon Error 5100
            Canon Error B200
            j
            c
