jam 74 75 DP-750B
  • brancas
    • Jul 2009
    • 80
    jam 74 75 DP-750B
    brain teaser, jam 74 75 on DP-750B. feeds only 1 paper through and jam code is displayed. loaded latest firmware about 2 change sensors next. any other advice?
    • 23009
    The manual recommends testing: Sim U244 for DPTSW1, Sim U243 for OFM, OCM
    Possible solutions: 1) Defective DPTSW1, 2) Defective original feed motor (OFM), original conveying motor (OCM).
    • yakyitz
      • 245
      Check if the black plastic frame holding pickup roller and feed belt is broken. The little plastic hook holding up the lead edge. if it's broken and hangs down a bit too far you'll get wierd jams.
      • brancas
        • Jul 2009
        • 80
        i tested said switches and motors according to the service manual, all was well. I replaced the DP original feed belt and DP forwarding pulley because the paper was jamming from that section ,no joy. I replaced the DP timing switch 2 (DPTSW2) no joy.
