C0330 error code
  • brancas
    • Jul 2009
    • 78
    C0330 error code
    changed mode setting in MM935 on Taskalfa 620 from 1 to 0 to match settings on another copier to correct alignment problem, but cannot change back to mode 1 and now a C-0330
    error code is displayed. Please help!
    • 22934
    It sounds to me like this machine had a Relay PWB communication error before you arrived. The "1" setting is designed to allow the machine to temporarily operate until the communication error has been resolved. It's not intended as a permanent fix.
    The manual suggests: 1) Reseat YC26 @ main PWB & relay PWB, 2) Replace relay PWB, 3) Replace Main PWB.
    When the communication problem has been resolved the machine will let you select the "0" setting. =^..^=
