FS-4020 Paper tray set up issue.
  • vedder
    • 131
    [Misc] FS-4020 Paper tray set up issue.
    Hi everyone.
    After a bit of assistance if anyone can help, I have a customer who has a FS-4020 printer (actually the UTAX version LP3245) who has 2 cassettes, letterhead in tray 1 and plain a4 in tray 2, whats happening is when the a4 plain runs out, it goes to tray 1 using thier letterhead stock, I have changed it from auto to fixed, but I think that might fix tray 1 and not 2. Is there a setting on the printer to sort this, or should I be looking down the print driver route, would it change things if I set the default paper tray to tray 2 on the printer?
    Any help appreciated.
    Cheers.
    • 23003
    I think my preference would be to make these changes as your printer defaults, by sending the following PreScribe command:
    !R! FRPO R1,0; FRPO R4,2; FRPO X1,9; FRPO X2,1; FRPO X9,0;EXIT;
    That breaks down as:
    FRPO R1,0; auto tray switching disabled
    FRPO R4,2; printer default tray2
    FRPO X1,9; tray1 media type letterhead
    FRPO X2,1; tray2 media type plain
    FRPO X9,0; tray selection based on media type
    You can make some of the changes in you driver defaults:
    Source: Tray2
    Media Type: Plain
    but you would still have to send a PreScribe command to disable auto tray switching, and to default tray selection based on media type:
    !R! FRPO R1,0; FRPO X9,0;EXIT;
    • HenryT2
      • 962
      Do you have the ' SIZE ' selector set the same on both cassette's ?
      If so, you may need to change the Letterhead cassette to " OTHER " setting .
      "The Serenity Prayer" . . .
      God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
      • cysec
        • Jun 2008
        • 21
        Re: FS-4020 Paper tray set up issue.
        Did you ever get a working solution for this, from what I can tell the FRPO R1 has been removed from most of the newer Kyocera models (falcon 3+ for copiers, and apparently sometime before the FS-4020)
        I'm dealing with this same issue with a customer where we cannot define different paper types due to a software limitation.
