J32 on KM 8030 or D800 or CD1080
  • habik
    • 2013
    [Jamming] J32 on KM 8030 or D800 or CD1080
    I am having intermittent jams J32,from Deck 1 and 2, Changed FSW1,2 and TIMSW1 and have new set of tyres on both decks. Cleaned whole of registration all rollers in reg are almost like new now Copier done 1.4 mil. Do these wear out? the long black(rubber) + plastic (nylon)
    Firmwares HERE
    • 23010
    Re: J32 on KM 8030 or D800 or CD1080
    Do you have the copper colored separation springs toward the front, and set to one notch higher than the original setting (on tray #2 it's two notches)? Also look at the condition of the mylars around the separation rollers, and whether the PE sensor flag is damaged-bent.
    I may be missing something, but I've got machines with 2M and have only cleaned these rollers at PM intervals. =^..^=
    • JustManuals
      • Jan 2006
      • 9838
      Just Manuals | The Internet's largest selection of manuals | Instant Downloads
      Paul@justmanuals.com
      • kyocera.team
        • Aug 2010
        • 126
        in registration section there's pulley one way look at this and check what condition about it... good luck
        • habik
          • 2013
          Thanks I still play about and I got new type mylars, new spring although I have to say 1 machine already had it and It was still misbehaving.
          Going to check the pulleys, they usually never go wrong, Either way, that one way pulley is only a bridge between those 4 registration rollers (2 nylon up+2 rubber under) so you can move misfed paper from registration out on to the transfer belt.
          I think I might have issue with paper. It is stored in huge airconditioned room, and I am suspecting humidity levels to be too high. I had a load of fresh paper unboxed over 2 nights and I think it jammed less from that stack.
          will keep you posted Thanks Black Cat and Kyocera team. ..hm time to check humidity levels.
          Firmwares HERE
          • habik
            • 2013
            OK Humidity levels of paper storage room were:
            64-65% with 16 'C
            pretty damp considering ideal storage conditions for paper are
            44-54% at 18-22'C
            how am I suppose to setup machines to work with paper like that, if even heaters switched ON did not help much.
            Any suggestions? ..
            On top of that it is a budget A4 80 gsm paper and it was a lot of it....bout 480.000 sheets in 2 weeks. So I had busy machines.
            Firmwares HERE
              • 23010
              The best that I can suggest is to get a couple of those cases of paper sitting next to the MFP, so the paper can start adjusting to the office environment.
              I had a situation years ago where the paper was stored in an uncontrolled environment. In the winter -12C, in the summer 43C, and humidity all over the map. The customer would call for jamming right after installing a ream of paper, then by the time I arrived, it didn't jam anymore. 5 return calls later, I was running the sheet out of the machine and ran out of paper. The office manager walked me out to the warehouse, where the heat just about knocked me off my feet. I could hardly hold the paper it was so hot. Just keeping 4 reams on the shelf nearby acclimating, resolved this issue. =^..^=
              • xeroid
                Document Technologies Pro
                • 148
                Watch out for the metal turn baffle into the registration area as viewed from the right side paper path. What I found was a bent baffle toward the front of the machine. Use a flashlight and inspect the gaps where the paper enters the the verticle transport from both trays 1 & 2. If it isn't even front to rear you can repair this by applying pressure to the front side of the metal baffle where it mounts to a bracket. You should see the gap even out. Another clue is you hear a slight metal scraping noise when slowly pushing drawer back in. I believe that the cause of this is the customer pulls the drawer out prior to removing the paper from the right side and when the paper crunches up on the front and binds the drawer, they angrily continue pulling the drawer all the way out thus bending the baffle and altering the paper transition into the registration area. My symptoms were J32's from Tray1 and skewed feeds along with J32s from Tray 2. Hope this helps
                • habik
                  • 2013
                  Thank you Xeroid, I will most definitely try and check your suggestion. Shoul have the machines back by next week, so hopefully I will be able to check them out properly and try side by side any how they all behave with the same paper and different :
                  Adjustments of the buffle (still wondering what exactly that word buffle means assuming is the paper guide where FSW2 is placed under.
                  I Thank you very much that you shared this info, I kinda did not believe that it could create enough force to actually bent that thing so much.
                  Will keep you posted whether it resolved the issue.
                  My biggest worry is still the paper. The only way to test is to use another 5 boxes of another brand put in the same enviroment for at least 5 days and than test it, but that is now impossible. I'll try my best.
                  Thanks Black Cat,
                  I was already acclimatizing the paper by taking it out of boxes and leaving the rims next to machines or very nearby by lying it down flat and few upright just to see whether it makes any differences crazy I know but had to try almost any possibility as I could not change paper supplier at that time.
                  Will keep you posted with results and tests.
                  Firmwares HERE
