CS 2560
  • TONERINMYNOSE
    • Aug 2010
    • 114
    CS 2560
    Got a machine dropping date and time, gonna change battery cant find part number, just your standard cmos battery?
  • Metalvoc
    • Sep 2008
    • 155
    Re: CS 2560
    I'm not sure you can replace the battery separately on those models. Could be wrong, though. Has this happened more than once? Does it happen immediately, or is there a span of time before the time changes? What does the date and time change to? Check to see if you have it set to connect to a time server. Also, make sure that your firmware is up to date. If it is, re-load it.
    I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
    • JustManuals
      • Jan 2006
      • 9838
      Re: CS 2560
      According to the service manual, the battery can be replaced.
      • JR2ALTA
        • Feb 2010
        • 2033
        Re: CS 2560
        bring to batteries plus. i've replaced many fax batteries there
          • 23009
          Re: CS 2560
          It is BAT1 on the MPWB. I can't find any specifics in the manual, but you can usually read whatever specs required right off the battery itself. They're usually 3.6vdc. The simple test we used to do on the early Mita's is to put your meter on the battery, the turn off the machine and unplug it. It's usually charged off of the 5VDC logic line, so when you unplug the machine the battery will quickly drop to 3.6vdc. A good battery will hold somewhere around 3.6vdc. A failing battery will keep dropping to 0vdc, often within less than a minute.
          If you have have to de-solder be sure to use a heat sink on the legs as you de-solder/solder. It's no fun when the battery explodes in your face, or you cook it to death. =^..^=
          • JustManuals
            • Jan 2006
            • 9838
            Re: CS 2560
            The standard battery for printers-copiers and PC's is the CR2032.
            • kkendric
              • 301
              Re: CS 2560
              Thid model uses a CR2032. Located lower rt side of main board, black upright holder.
