The machine has finally completely shut down, but the fuser is still in good shape and we are in the process installing a new machine. Is there anyway of resetting the page count on the fuser with a fuse, or a chip, like the drum units and transfer belt?
KM-C2230 Requesting fuser replacement.
Tags: belt, drum, fuser, fuser reset, good, km-c2230, kyocera, page count, replacement, reset, transfer
Re: KM-C2230 Requesting fuser replacement.
If you don't have pico fuses handy, I have soldered (and even used electrical tape) standard 1/4 amp fuses in place of the pico. The fuse is on the fuser connector. Just snip the old one out, and put the new one in its place. If you are adventurous enough to tape one in, I would recommend removing it once the fuser is resetI must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark TwainComment
