KM-C2520 NO DISPLAY
  • EDSNOW
    • 180
    [Misc] KM-C2520 NO DISPLAY
    Hi Everyone
    I have a customer 300 miles from here with a blank display.
    I just wanted to ask if anyone else might have had a similar issue and what the resolution might have been.
    I would have to order a replacement OP UNIT which isn't a problem but I thought I would ask. I don't expect the customer is able to do anything in the interm other than perhaps print.
    ED
  • Metalvoc
    • Sep 2008
    • 155
    Re: KM-C2520 NO DISPLAY
    I have had a couple customers move the display density wheel unintentionally. (though not as common as it used to be) You might have them spin that back and forth, to see if they get something to come up. If not, when they touch the screen, does it still beep when the press the invisible keys, or is there no function from the display panel at all?
    If the touch screen and hard keys are still working, I wouldn't order an entire op panel, just the display.
    I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
      • 22927
      Originally posted by Metalvoc
      I have had a couple customers move the display density wheel unintentionally. (though not as common as it used to be) ... If the touch screen and hard keys are still working, I wouldn't order an entire op panel, just the display.
      Like he says. =^..^=
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
        Paul@justmanuals.com
        • EDSNOW
          • 180
          Thanks for the responses.
          I phoned the customer and verified the display panel is indeed lit up but no activity for any of the selection tabs. I trusted the customer to try a MM 906 and 201 but even then when required to push the required tab nothing happens. I do have an operation panel on order so I expect that is my next option. Machine is still under warranty so at the end of the day an RMA will work out.
          Just an inconvenience in travel distance and time.
          I will follow up with the resolution.
          • tech07
            • Aug 2008
            • 409
            I've had quite a little run on op panels lately..I only had to replace the touch op panel. Nothing else. Just be careful when removing the foam pads around it's rim. you'll need to put them on the new one. I would venture to say we've gone through ( 8 techs ) about a dozen of this part in the last 2 months
            • EDSNOW
              • 180
              Many Thanks for the response tech07.
              I appreciate.
              ED
              • EDSNOW
                • 180
                When I got onsite the operation panel was working.
                I removed and reinserted the connectors anyway and did the display MM simulation to set display.
                Checked operation and while doing other work around town I checked back before leaving. Regardless I left the new part at the
                customer location in case there are future issues.
                The problem with this kind of call is the remote location and being only one of a kind product anywhere in our dealership.
                Ed
