power supply problem
  • kamongo
    • Jan 2011
    • 16
    [Electrical] power supply problem
    anyone can help me.
    i have a km 2560 machine,when i turn it ON it just start to initialize then cut power.if you switch it OFF/On nothing on the display.it just start and turn off immediately.
    Please anyone can help me plz.
  • Jules Winfield
    • Jul 2009
    • 821
    Re: power supply problem
    Was any work done to this machine recently? Perhaps a voltage supply wire got pinched and is being shorted to ground.
    But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
    • kamongo
      • Jan 2011
      • 16
      when i use the generator the problem occurs sometimes.when this occurs when i disconnect everything from the power supply and connect again the machine initialize ok.
      • Jules Winfield
        • Jul 2009
        • 821
        Ok, that explains it. You should always run copiers on their own dedicated circuit to avoid weird power issues. Not only that, but the copier should be connected to a surge suppressor and not just plugged straight into the wall outlet.
          • 23009
          I wouldn't trust a digital copier on a generator. The power is too dirty. I would use some kind of a power conditioner in between the generator & MFP. =^..^=
