I am the second company to come out on an existing previous problem with a KM3035. The sorter is shown installed and can be sellected, but all copy and prints and faxes come out at the catch tray. The copy company that came out before me tried and left another sorter at the location, with the same result. checked connection and there is no fault code. tested sorter drives in diagnostics..with no results. any suggestions? (other than a bigger hammer!) , Arnie
Sorter not recognized by Kyocera KM 3035
Re: Sorter not recognized by Kyocera KM 3035
Have you tried selecting the sorter tray as the output? What happens when you try to select the finisher tray output? Have you run a U906 partial reset? Or if printing, is the machine properly configured in the driver to show all the attached accessories. Is the finisher tray output selected when printing? Not much information here. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
I CAN SELECT THE SORTER TRAY AS THE OUT PUT ON THE SCREEN WITH NO ERROR AND IT HIGHLIGHTS THE FEATURE. PUSH PRINT AND THE PAER COMES OUT IN THE CATCH TRAY. IT HAPPENS IN PRINTING ,COPIER OR FAX MODES..i CHECKED INVERTER GATE ..INVERTERGARE SOLOENOID ACTUATES IN DIAG. RAN U249. U002... WOOOW i FOUND THE CODE ... I NEED TO DO A U906.. THANX BALCKCAT4866 ILL LET YOU KNOW HOW THAT CHECKS OUT. MAY BE THE TRICK SINCE THE LAST TECH MAY HAVE FUALTED IT OUT BUT DIDNT COMPLETLY CLEAR IT WHEN HE PUT ANOTHER SORTER ON???!!
SINCERLY ARNIEComment
Yes, heavy paper will not output to the finisher, only to the top of the machine. In U000 print off "ERROR". You'll get a list errors, and the number of occurrences of each. Look for a C8xxx error to lock out the finisher. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
the paper is normal setting on 8.5x11 standard weight. tried 14" too. the inverter gate (directs it to the finisher)doesnt even try to engage.no error code in listing. the customer wont be in till next week. ill give u906 a try then.Comment
