Error code for Kyocera KM-C3225e model
  • Caldo
    • 69
    [Error Code] Error code for Kyocera KM-C3225e model
    Hi guys,
    Sorry for the copier model number, it is not KM2560, it is a color copier model number KM-C3225e with the error code # C9540.
    thanks
  • JustManuals
    • Jan 2006
    • 9838
    Re: Error code for Kyocera KM-C3225e model
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • vigour
      • Aug 2010
      • 1038
      no canon parts will fix that
        Your should contact admin and get them to move your post to the Kyocera forum.
        The service manuals not much help with this error
        C9540 - Contact the Service Administrative Division.
          • 23009
          Codes in this range are usually reserved for the illegal copying of currency, bonds, financial instruments, etc.
          You can inform this customer that each copier embeds it's serial number into the pattern in the printed image. So if this currency is passed the Treasury Dept. can track you down and throw your ass in jail for forging money.
          Naughty, naughty, naughty! =^..^=
          • Caldo
            • 69
            Blackcat,
            Thanks for that, i should have noticed earlier. Well guess i just have to see the customer and try to explain some sense into him.
            Maybe i should post to the kyocera forum for any info on reseting this error code.
            Heaps of thanks guys.
              • 23009
              Try a U906. =^..^=
              • Aneurysm
                Administrator
                • Jan 2005
                • 1083
                OK - Bump!
                • jmaister
                  certified scrub
                  • Aug 2010
                  • 755
                  This is really the meaning of the code? Attempt of forgery?
                  Idling colour developers are not healthy developers.
                  • Caldo
                    • 69
                    Agreed, whatever you may call that! anyway thanks guys (blackcat) got the problem solved. Just gota remind the customer again, hahaha!!!
                    cheers
