taskalfa 820
  • kyocera.team
    • Aug 2010
    • 126
    taskalfa 820
    hi all
    i have 5 machines task alfa 820 all are working fine only one machine slow print slow response.
    i am thinking about dimm memory or the print system it self ?
    same printer driver for all but only this machine very slow ...
    any idea ? thank you
    • 23008
    Re: taskalfa 820
    It was a good idea to test print from the laptop. You've already ruled out network & driver installation.
    The things I would try? In this order:
    1) Re-install/upgrade/replace image memory.
    2) Print maintenance report & network settings. Perform U020 Memory Clear. Re-enter maintenance report values.
    3) Replace printer NIC.
    Good luck. =^..^=
    • jmaister
      certified scrub
      • Aug 2010
      • 755
      Re: taskalfa 820
      any special message on the screen?
      Idling colour developers are not healthy developers.
      • kyocera.team
        • Aug 2010
        • 126
        Re: taskalfa 820
        Good luck. =^..^=
        i test it from my laptop but same result .
        today im going to change printer card with a dimm memory . from my side i will try to clear memory as a last option
        thanks dear black cat
        • kyocera.team
          • Aug 2010
          • 126
          Re: taskalfa 820
          no message no error code
          thanks dear jmaister
          • kyocera.team
            • Aug 2010
            • 126
            Re: taskalfa 820
            thanks all
            i went today to customer side i changed the dimm memory and machine working fine now
            thanks again
