HammerMill paper, laser, laser gloss, better than butter?
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    From a 250Ci Pantone package there's a text file (cant remember the name as usual lol), that states
    "HammerMill, 28lb, 100bright"
    I guess KM/CS is using hammermill as test paper tho not officially endorsing them.
    Question is this, with Hammer's no jam 99.99% guaranteed, is their avg laser paper better than the avg of others?
    Would it be so much more better that it decreases jam occurance?
    Idling colour developers are not healthy developers.
  • vigour
    • Aug 2010
    • 1038
    Re: HammerMill paper, laser, laser gloss, better than butter?
    it produces much better quality of print/copy
      • 23009
      IMHO any 24# or 28# media will jam less than any 20# media. Hammermill is good paper, but any heavier media will produce the desired effect.
      Now if trueness of color is your aim, look for the 100 brightness. Again, Hammermill is good paper, but any 100 bright paper will produce a truer color.
      I am cautious about any gloss media, and always check that it is gloss laser paper, not gloss inkjet paper. And confirm that proper media settings are used. Inkjet paper will destroy your fuser in two shakes of a cat's tail. =^..^=
      • jmaister
        certified scrub
        • Aug 2010
        • 755
        thx chaps
        Under-educated lad like me will need to read the following, Pls
        SMI: Bulk, Prosperity & Smoothness
        • Ianizer
          • Jul 2011
          • 380
          What Blackcat said.
          Although, I am of the opinion that brightness is overrated.
          Paper is the fifth color and, as all experience hath shewn, it's beneficial to a greater degree to calibrate properly maintained gear with the stock normally used -- the key being a high quality smooth stock -- rather than focus on some whiz-bang "120 Brightness" paper. 90 brightness (again, some may disagree) is just fine. (Besides, at a certain point they just add blueing to fool the eye.)
          Brightness, has more to do with personal preferences for the end product than it does with the device ability to lay down a quality image.
          And, of course, smoother stock will have the side effects of a cleaner running box and less wear on paper-path parts since it's less abrasive.
          Hammermill 24 and 28# laser presentation stock is a very good product, as is Xerox' Expressions line.
          -I
          My name Peggy.
          You got problem?
          • jmaister
            certified scrub
            • Aug 2010
            • 755
            One client was using Zrock's Xpres-ci-on, really nice stuff.
            The HummerMill Laser Gloss is what I'm actually interested in, looking for a place to get them in store (Staples dont got them).
            This is what I have in mind...
            Test Equipment/Setting:
            Saturn/Alphard
            Paper type: color laser(high quality / normal3, for 28lb), or laser gloss (coated / heavy1 , 32lb)
            driver and machine setting has to match.
            PDL: KPDL, allow data passthrough
            Driver Profile: Pantone* (has to be installed through setup wizard, unless there's another way)
            CMYK processing: 4 channels
            Adobe file: Made with Genuine Pantone color.*
            *If Pantone is not available, still use KPDL, as its the only option to allow 4 channel processing.
            Then! compare with PCL XL, PCL 5C.
            Should be interesting to see.
            edit: Pls, if anyone has the equipment/time/paper type, try it out.
            • Ianizer
              • Jul 2011
              • 380
              Saturn/Alphard
              Okay...
              Huh?
              -I
              My name Peggy.
              You got problem?
              • jmaister
                certified scrub
                • Aug 2010
                • 755
                hmm, another of those impulsive post from me I guess(cant help it, seriously), apology for that.
                This paper interest has tickle me enough that I want to do a quality test with KM machines, but lacking equipment due to a smaller shop, was looking if people could volunteer and share their result.
                J
                • Ianizer
                  • Jul 2011
                  • 380
                  J
                  Oh. Well. GIGO is a good rule of thumb.
                  Tickles me how people with invest in a umteen-thousand dollar MFP and then run the cheapest crap paper they can lay their hands on...
                  Hammermill's just a big, well known brand. Good stock, but a big name.
                  For best image quality & performance, run good quality stock that's kept cool and dry.
                  Know what "good quality" is is key. IMHO.
                  -I
                  My name Peggy.
                  You got problem?
