task alfa 620
  • kyocera.team
    • Aug 2010
    • 126
    task alfa 620
    hi all
    task alfa 620 giving error code C0630...
    replacing the main board
    update firmware
    still error code C0630...
    any idea
    thanks
  • taskalfa
    • Jun 2011
    • 97
    Re: task alfa 620
    I had a similar issue with taskalfa 520i , i had to replace dimm on main pcb.
      • 23009
      Re: task alfa 620
      On the Falcon III series C0630 is a communication error with the CIS for the second side. The usual cause is the harness or connectors. That's where I would start. =^..^=
