taskalfa 820
  • kyocera.team
    • Aug 2010
    • 126
    taskalfa 820
    hello friends
    this week i had a lot of problems with my machines ....!
    i have task alfa 820 copies are OK print out from PC also OK just when i try to print counter or service call or jam code it's print full black any idea ...?
    by the way i changed HDD and laser but still the same .....?
  • vmchong
    • Oct 2008
    • 22
    Re: taskalfa 820
    Try update the firmware!
      • 23010
      Re: taskalfa 820
      I can't remember what model it was, maybe Saturn, but it wouldn't print any internal reports. Not like an image problem, it just wouldn't allow it.
      Firmware fixed that one. =^..^=
      • kyocera.team
        • Aug 2010
        • 126
        Re: taskalfa 820
        thanks my friends
        i already update firmware but same result ...
        i'm going to work now and i'll see ..good luck for me
        • Zackuth
          • Aug 2009
          • 448
          Re: taskalfa 820
          I had something like this happen on a 4035 machine once. The service reports all came out with black blocks where the information should be. I 906'd the machine and the reports came out like normal.
          If at first you don't succeed, redefine success
          • vmchong
            • Oct 2008
            • 22
            Re: taskalfa 820
            You can collect the log data in U964, So can forward to Kyocera. They can trace for you.
            • kyocera.team
              • Aug 2010
              • 126
              Re: taskalfa 820
              finally....
              problem solved by replacing the memory (main board memory )
              thank you all
