Taskalfa 300ci intermittent fade vertical lines on print out
  • Realtech
    • Oct 2009
    • 103
    Our Taskalfa 300ci has intermittent fade vertical lines on print out.
    This machine has almost 83K print out and some times intermittent fade vertical lines appear on the paper during print job.
    Any Idea?
    • 23008
    Re: Taskalfa 300ci intermittent fade vertical lines on print out
    When you say vertical, does that mean main-scan direction (cross-feed) or sub-scan direction (feed direction)?
    If they are cross-feed and appear on your U089 Gray test patterns, I'd look at primary charge for the affected color(s).
    If it's feed direction, I would suspect severe overtoning dumping toner on the laser slit glass. That laser slit glass cleaner cycles periodically, and would make it disappear unexpectedly.
    Both conditions can be intermittent. =^..^=
    • Realtech
      • Oct 2009
      • 103
      It's intermittent the fade vertical lines are gray.
      It's happen intermittent so U089 was not useful for me.
      If I make the laserscanner cleaning cleaned more frequent that would help?
        • 23008
        Originally posted by Realtech
        It's intermittent the fade vertical lines are gray...
        Am I just dense, or did you not answer this question? (crossfeed versus feed direction, or main-scan versus sub-scan direction). "Vertical" depends on the orientation of the original and the orientation of the copy paper, and you have not told me either.
        If I make the laser scanner cleaning cleaned more frequent that would help?
        You can increase the frequency of the laser scanner cleaner, but I think it would be better to resolve the overtoning. It always works out better when you fix the cause rather than the consequences.
