KYOCERA KM1635
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Error Code] KYOCERA KM1635
    hello every technician ...l know this is my second thread about this problems ...a error code E6000 in km1635 ...despite l tray controlled all component for her fusion section but all parts is good ..please can anyone help me to result this problems ..it have solution to reinitialized this machine ..??
    BEST TECHNICIAN . NICE PEOPLE .
  • Eric1968
    • 2458
    Re: KYOCERA KM1635
    Reset the error with U163.
    • zaza
      MECANOGRAPHE
      • Mar 2008
      • 1095
      Re: KYOCERA KM1635
      thanks friend Eric for your assistance ....l was regulation my problems ...
        • 22997
        Re: KYOCERA KM1635
        Does that mean that you cleared the error? =^..^=
        • kyocera.team
          • Aug 2010
          • 126
          Re: KYOCERA KM1635
          this error also related to power supply also if all parts are good
          • temas
            • May 2011
            • 22
            Re: KYOCERA KM1635
            @ black cat.i have a km1635 that is bringing this error c6000.fuser unit and power board are tested OK on another machine. i cannot enter stimulation mode to clear the error.what can be the cause of this
            Do not find fault, find a Remedy, anybody can complain.
              • 22997
              Re: KYOCERA KM1635
              The only way that you'll clear the error is by entering service mode, sim U163. That's it.
              Opening the front door, then try to enter service mode. =^..^=
              • marc
                • Feb 2010
                • 56
                Re: KYOCERA KM1635
                Make sure that all the numbers are working fine try 3036,3036 good luck!!!
                • JR2ALTA
                  • Feb 2010
                  • 2030
                  Re: KYOCERA KM1635
                  Remember you can pop the thermostat if all else is good. I prefer whipping it against the ground.
                  • kyocera10
                    • Sep 2011
                    • 13
                    Re: KYOCERA KM1635
                    yeah throw the thermostat
